Mike Sweeney
Well-Known Member
So when I was working on the bottom side, I snipped off some of the old vinyl ties to work on the boards. All of sudden my sound goes completely away. I worked out that I had a short.. Somewhere.. I ended up re-soldering the selector switch, a couple of weak connections on the tuner board and generally going crazy. But today I decided to "do or die" and I found it.. underneath one of the boards, there was an orange wire that had been shoved against a standoff corner edge and over time, it abraded the jacketing. As I moved the wires, it will touch and short out all sound and then when I moved them against, it would lift and work again. I ended up cutting it in half, putting some heat shrink on and then resoldering it then putting the heat shrink over it. What a PIA. . but it's fixed
You can see the abraded jacketing and the guilty stand-off below it. This took some work to find.
And yes, I'm back
I had to build a new workbench and renovate my part of the garage for the past two months
And yes, I'm back
