Kale
Because the server, where the pictures were located, is down, I am going to copy the post where I was talking about ground connection in G8000, but this time with uploaded pictures here on AK, so....
BTW, here I wish to show you only one modification what I made in that receiver. You know that at beginning of some restoration, you should decide will you make only restoration or you will make some modifications too. On that receiver, I decided to do only restoration, but one thing, Sansui did on bad way. To correct that Sansui mistake, I have had a big help from another Croatian member ilimzn.
So first about what I am talking here;
There, I am talking about connections of main capacitors. You know that G8000 has 4 pcs of 6800uF capacitors per channel, and that is very good, but Sansui made a mistake how they are connected. First of all, wire of ground is so long! Second, wires of power supply and wires of power stage are connected into one point.
So, we need to separate pair of power supply capacitors from capacitors of power stage, and make better ground wiring.
I did that job on the next way:
and finally:
As you can see, pair of power supply capacitors I connected with pair of power stage capacitors by solid wire in Teflon insulation trough ferrite to protect power stage against HF noises.
Once again, thank you so much ilimzn for advices!
and finally:
