I was curious if there was anyone that has come up with a way to cross reference replacements for older Marantz 34-**** transistors. I have a tone board with 34-1008, 34-1010, and 34-1031 that is making some noise and I can’t seem to find any input on good replacements.
Check this thread out as for as a cross reference. The author appears to have put some time into creating it.
https://audiokarma.org/forums/index.php?threads/marantz-19.903790/
Regarding board removal. You are correct. After removing the front pot nuts, the only thing holding it in is adhesive. I was able to remove the tone board in my Model 19 by taking my time and just starting in one corner. I was sure something else was holding the tone board down because the adhesive was fairly strong. However, it did pull up. Once you get it going, just move slow across the back of the board. Much easier to work on when removed.
