First impression AU-555a
stereofun
The AU-555a arrived a few hours ago. It came from Florida, sligtly rusty on the inside but even moreso covered in a tough grime throughout mixed in with the remnants of an old coffee spill thats had covered the caps and main board with residue. hmmm.
I deoxed, and blew dust out, while noticing a slew of flying saucer trannys abound. My expectations sunk.
I hooked it up to my trusty modded Dennon 2800 Mk II that so far has survived several attemps of replacements by beating all contenders by virtue of it sonics. Then on to my modded Wharfedale Diamond 8.4
The Au-555a is a quasi complimentary push-pull, cap coupled design - Old school with capital O. While the tripple tone controls are not attenuated, but merely detented, the build quality of the 1971 piece is very solid with thick shielding throughout. No ic's and plasticc connectors - just solid print and what appears to be simply straight forward signal processing.
Ok - time to fire up. I begin with no signal and am surprised to find it dead quite - no scratcyness, no hissing or any popping at full volume - silent. I then load a Shirley Horn cd, crank it a little and lean back. Wau!!!!!
Its true what they say - this little meager 20 some watts amp has balls and presence. Lots of texture, punch and plain musicality. What a joy.
Sure it is a little accentuated in the upperbass/low mid as many of the "warm" sounding 1st gen solid states - but what really impresses me is the texture of the sound, especially voices that comes across with a rare authenticity. The sound is very non fatiguing and displays and "unprocessed" quality, almost as if the amp is doing everything not to stand in the way of the signal.
Overall, this totally stock (and neglected) Au-555a is a treat to listen to, not only with jazz and arcustics, but even punchier genres where there is great bass detail and power available. Definitely worth a recap job.
My reference is two fully recapped and adjusted Eight / Au-517
If anybody has trick and tips for modding / recapping, I am all ears :-)
The AU-555A is a nice amp. I replaced the flying saucer transistors in the one I had and did a full recap. It is the one piece that I noticed a difference in sound after the recap. Mainly, the bass tightened up. If I hadn't picked up my AU-888, I would still have it.
Rob
Stereofun
I just rebuilt my 555a. I replaced all the electrolytic caps, removed all the resistors and measured them, replaced what was out of spec. The flying saucers I replaced all of with new transistors (there is a post I made which lists the transistors that I selected, I was hoping for some feedback on my choices but I got zip). I you search my posts you can find it. Some of the electrolytics I replaced with higher voltage ratings (for example 1500u 63v went to 1500u 80v). I would enjoy hearing from you as to your transistor selections. If you want to contact me of list I could send all of the info I have.
Thanks alfetta - did see you post. Yes will definitely get in touch later for some details. I did a flying saucer replacement in my Eight and used the same part number as you for the npn version, no issues, just suprised at the gain difference that went from 25 to 150 or so - but that is normal when you replace 40 year old trannys.
Trnsfrm is another AK member, who is very knowlegable about this model and mods to go along. Your recap work looks great by the way!!
Hi Stereofun,
I like the picture of the Eight power transistor. You have to have one to recognize it. LOL My Eight still isn't working.
I have recapped so many 505's and 555's that I have lost count. I'm up to at least 10. These are a couple of the best small amps ever made. If you like it now, wait til you do the recap.
I'll give a few suggestions. I raised eyebrows on an earlier post on the 999, but it is my opinion that if your unit works well, just leave those flying saucers alone. I dunno, but both my AU999s have the things throughout, and I just love the sound. At least, do everything else first, and if you're not satisfied, then change out the transistors. If it works great, and sounds wonderful, why fix a non existant problem.
Sansui really nailed it with this amp architecture, more than any other company ever has. GUARANTEED, your output caps are toast. They are probably way less than half the marked capacitance and have so much leakage they almost can't be measured. They are the most important parts for upgrading the sound. Use caps designed for switching power supply use. The stock ones are 1500uf. For use with 8 ohm speakers use 5600uf caps. For use with 4 ohm speakers (I don't recommend) use 10,000uf caps. You need high ripple current spec, and that will only be provided by switching power supply caps.
Change the big power supply cap to 4700uf, stock is 2200.
If you want, you can add a polypropylene 12uf @200v cap across the output cap. I used to be really sold on this idea, but since upping to 5600uf on the ouputs, I don't think it makes much difference.
Set the offset by measuring the power supply voltage at the big power supply cap. Then measure the voltage at the + of the output caps and set it to 1/2 the supply voltage. that's the easy way.
Set bias to 20 ma, AFTER it has been run hard for a while. All of these that I have worked on have a bad case of drifting bias. Cold, typically, you will measure 8-10ma when it is adjusted right.
Don't be surprised, if you end up liking this thing as much as your Eight. It's a little monster.
Ok here are pics!
Such a classic beauty!
Thanks Jim (trnsfmr) for all your info. Will get back for specifics. Thanks Tom
