First Time Amp Repair - Sourcing Mosfets
Scott March
Hi All,
I decided to try my hand at Amp Repair as a hobby. Just picked up a Hafler SE240 that has a blown channel. Took a look. MosFets are definitely fried. Going to continue diagnosing the other components. My question is that its using 2SJ161/2SK1057 pairs that don't seem readily available. I poked around the typical sites and all I see are China knock offs. Is there any reputable place in particular that I might be able to source the components... Thanks for you help.
Scott
Bumping an old thread but, to the OP, I’m trying to remove either the faceplate or the bottom cover without having to resolder anything or glue anything. Is this possible. I’ just trying to install some rubber feet onto mine and can’t get to the back two.
Thanks
Thanks
Are you working on a Hafler SE240?
