So you guys saying if I have rb300 rega arm I have to use rega card stock protractor for align or I am compromising design?
Either use that or worse yet buy rega 3 point mount cartridge only way to be correct with align?
I do not think so
Or same thing only way alignment be design correct is with factory head shell on mass produce type turntable arms?
So why people like orsonic work so hard to give flexible options to public advanced hobbyist?
Alignment schemes in owners manual back in 1970s for simplicity and I also say MAY BE SOME stand alone tonearms MIGHT be alignment specific but that VERY rare
Because if what you say true then why all those old guys work so hard finding new null points to work better for different stylus and cartridge types?
Also Lp grooves AND styli change from 1950 to 1980s so alignment choices might change too for some Lp lover
There is no rule correct align for any tonearm cartridge combination except use one that works best
And
WaynerN OVER HANG is NOT same thing as ALIGNMENT I not debating EFFECTIVE TONEARM LENGTH or OVER HANG but position of cartridge can be changed for different null points you choose and still maintain manufacturer EFFECTIVE LENGTH
EFFECTIVE LENGTH of tonearm is ONLY thing determined by manufacturer obviously
Technics gauge only address OVER HANG and leave up to SL-1300 or which ever one owner to eye ball rest!
One is apples one is oranges
So answer to
Rob_Feature is still yes he can use what ever null points he choose cartridge looks turned and still be 100% correct with his alignment
No such thing as manufacturer null points except ones they print in book for end user simple set up
And ALMOST NEVER do that ALMOST all Japanese CONSUMER type turntable from 1970s just gave measurement to use and set stylus tip position aka OVER HANG like 52mm etc
I own a LOT of turntables over years and never have one Japanese machine manual discuss NULL points not one
Only thing from manufacturer is EFFECTIVE TONEARM LENGTH determine by OVER HANG adjustment
Feel free to align how ever you want! ; - )
JJ
