First time speaker/driver ID request.
b_sdaddy
Well-Known Member
Dear All, Have tried searching on-line, but no luck.
This is my first ever speaker ID request!
I think they are either DIY and/or a kit.
The seller has no idea.
The driver (middle left) looks relatively distinctive so perhaps someone out there can ID this.
The woofer with its' ribbed cone is also quite distinctive.
Trying to establish there worth.
At 32" tall and cabinets that look well made, they might be worth the drive (50 miles each way)?
Seller wants 25.
cheers
Seller sent second photo. As you can see, the 'mid' has been replaced. This looks to be the original. Perhaps Fostex W422?
closer inspection of front label:
Super Luxe Professional Loudspeaker
Compromiseless 6 ohm 60w
Have asked for photo of rear.
Odd combination of front and rear driver mounting. About the only thing I can say definitively is that the dome tweeters are Philips AD0160. Label reads:
Professional
Compromiseless
Loudspeaker
System
8Ohm 60watt
Highfidelity
Stereo
Super [?] Luxe
Specifications
Based on the text, almost seems as if it's a white van speaker from the 1970s.
Professional
Compromiseless
Loudspeaker
System
8Ohm 60watt
Highfidelity
Stereo
Super [?] Luxe
Specifications
That's all I needed to hear. Thanks
