My GTI has the oil filter on top of the engine so the extractor pump looked worth a try. I got the manual one not wanting to fool with electrical cords or air hoses. With the one I got you have 2 different size hoses so you use the biggest one the fits. Comes with a wire that fits in said hose to help guide it to the bottom. The wire is shorter than the hose so you don't have to worry about scratching any internals. Maybe a minute and a half of total pump time and that's with me letting the car sit and trying to get more out. Not even a minute got 5 quarts out. Pumped about 10-12 times and got around a quart and a half out and pretty quickly. I'll pull the filter first next time as a small amount is left in it. There was about 5.5 quarts in it and that's what came out. Not really worried about a small amount left. I never waited till it stopped dripping anyway doing it the old way. Doesn't work on every car but I knew it did on the 1.8 and 2 liter VW's
Man it's nice not to have to crawl on the floor and take off all that stuff then put it back on. Also the 2021 GTI has a plastic oil pan so not running a drain plug in and out every time seems like a good idea
