Music power (Peak Wattage, EIA, IHF) watt's measurements were a TOTAL of the COMBINED CHANNELS for less than a second. This is peak wattage for dynamics. The ad doesn't say "per channel". It just says 65 watts Music power. Owning 5 different FISHER Receivers, I can tell you that the 175 is NOT capable of 65Watts per channel. If you converted the EIA, or IHF (Which FISHER was using at the time) peak wattage, to continuous RMS wattage, which is a continuous rating, and more like real operation, you'd get roughly 10-20 watts per channel. (remember that back then speakers were generally very efficient.) Which is equivalent to the power put out by the SX-434 (15-18 depending on 8 or 4 oHm load). I also own a 434, bought in 1974. Put them side by side and they are pretty much equal.
50W and better receivers and amps (RMS FTC ruling 1974) generally have about 8200Uf or better of main Filtering. The 175-T has 2000uf/50V of Main Filtering. This is less than the SX-434 which has 2 x 3000uf/25V of Main Filtering. My Sansui 2000A at 38WPC has 3000uf/35v Main filtering. There's no way the 175-T can put out 65Watts per Channel.
Pre 74 was TOTAL PEAK instantaneous watts total for both channels.
Post 74 was CONTINUOUS Watts PER CHANNEL. Some manufacturers also gave the peak wattage which would be higher. This is also referred to as headroom. The continuous watts were a more real world measurement than the peak measurement.
Imagine you are able to rev your engine to 7000 redline for a second. It makes say 250 horse power there. But only for a second. Now remeasure it in the realm of everyday driving, and you get say 180. Which would be more accurate for most people's driving style. I would think for everyone except for a few miscreants that love to hear their "fart tubed" 4 cylinder Sardine can's whine like a whore in church, the 180 would be a more realistic measurement. But Marketing hype and commericalism have jammed down our throats that 250 horses is better. But they don't tell you that it's at redline and for a second or two, (it's hidden down in the fine print, in amonst the garbage like how much domestic content there is in their car) and basically useless.
It's breaks down to which standard you use. Peak or Continuous.
Peak will say "so many watts music power, peak, or instantaneous".
RMs will say xWatts @ y oHms into 20 to 20,000Hz. per channel.
Larry
