WopOnTour
Hoarder Extraordinaire
OK I have been looking at my options for "robust" can caps for these and "think" I have it where I want it. I'm either going to use 3 of the 50/50uf 500V F&Ts per amp (with 3 sections in parallel to create the initial 150uF) or a slightly less expensive option is using only 2 F&Ts (a 100/100uf and a 50/50uf) with only minor effect on the voltages, ripple, and rise times.I've been messing with PSU Designer in an attempt to model the outcome.
I've also theoretically reworked the PSU to accomplish 2 primary goals:
a) to reduce plate voltages by approx 5%* in order to insure I had enough negative bias to reduce the EL34s to ~ 20 watts dissipation (about 45ma each) as the stock current was 62.5ma and 30 watts... way too hot! (especially if I strap them to triode)
b) to move the 3000 ohm resistor that's running in parallel with the primary B+ rail (and originally used to drop 470V down to 250V necessitating the 15-watt 3000ohm ceramic ww resistor you see mounted top-side for cooling.) and place it more conventionally at the END of the string.
*actually this was an accidental byproduct of the results from PSU Designer. Even when I created the stock power supply in PSU designer, the results were quite different from what I measured on these amps (which pretty much coincided with the SAMs schematic)
While I'm not exactly sure WHY the voltages are lower, in my modded circuit I just adjusted resistances in the filters to make sure ALL voltages were lower by ~5% from spec. Then if they end up being actually a bit higher than in the simulation, they will hopefully be proportionately correct for any increase.My assumption is that the voltages are all slightly lower because I have used the MAXIMUM current for each gain stage in the PSU model, and perhaps they are not all drawing their maximums in the Fisher 200 circuit.(other than the EL34s that are running full bore!)
So below are schematics for the original power supply, the proposed modified schematic, and the results I received from PSU designer (with additional text added to explain my load taps) Does anyone see anything wrong with the changes I've made??
So what I'm hoping is someone more familiar with using PSU designer can let me know if I'm using it right and if my operating points look OK.(full schematic in 1st post)
WopOnTour
WopOnTour
