Fisher 201 Stereo/Mono Switch
Keneye
Well-Known Member
Hi, someone gave me a Fisher 201. More or less working. Which is amazing considering one speaker switch was a 15amp fuse and the other was a slow blow! The mono/stereo switch is broken and not engaging. Before I tear into it, is there a replacement switch available? Otherwise I will just rig up for permanent stereo.
Picture of the offending switch would help. There may be something out there similar enough to work.
best bet is e-bay find another for parts. or tear into it and repair the switch handle (most likely broken at the pivot / hinge)
Mitsumi toggle switch. Broken inside.
A parts unit on ebay, facebook marketplace, craigslist, will probably be your best bet
Yep. I am checking. If not, ordered a similar switch and will moynt it in the original housing.
