According to the Fisher 400 schematic and parts list from Fisher-
C67, 68, 69, 70, 75, 76, 77, 78, 79, 80, 83 & 84 are ceramic coupling capacitors in the audio chain. C81, 82, 93, 94, 95 & 96 are mylar in the audio chain. The RIAA & tone sections are also ceramic flat packs with internal resistors and capacitors in the audio chain. Also the FM multiplexer in & out at 12AX7 includes C218, C220, C221 & C222 that are ceramic are in the audio chain. Me thinks a poly type capacitor will make for a better sounding FM section too.
Per being 'out' you are stating to all that read the original post upgrading the ceramic capacitors that are known for higher distortion is of no importance? Perhaps Fisher has some distortion cancelling attributes from section to section I am unaware of?
Stable and perfectly fine when the correct type is chosen.
A member here turned us on to that one! :yes:
Worrying over your same question!
Just because they all look alike, they work differently.
We used this type where film and foil would not fit or the value wasn't available.
http://www.mouser.com/catalog/specsheets/XC-600144.pdf
No need to be rude or argumentative to Don, he's a sweet heart and knows a LOT! :yes:
Seems to happen a lot when people don't like an answer.
Everyone has a way they like to approach things in this hobby as we have found! And a basis for that approach, sometimes objective, sometime subjective.
We figured that one out about an hour after we decided giving it a shot at restoring Daddy's old 500-C
You asked, he answered.
Phyllis[/QUOTE]
Rude? I did not use the word rude. You did though. Don did not explain any more than 'I'm out' (perhaps that is rude) dismissing the potential attributes of upgrades just like in any receiver and specifically the Fisher 400, 500 & 800.
'You asked, he answered'- Don's post is not correct- no coupling caps. From an engineering standpoint Don's post did not offer anything.
I never heard of an 'audio quality' ceramic cap. The ceramic caps have different temperature coefficients that can be critical in tuned circuits at RF frequencies, but not at audio. I have no concerns with ceramic capacitors in a shunt circuit to ground or applied to RF/IF applications.
However, I would like to hear from others if they upgraded their Fisher ceramic coupling caps before dismissing my original post. Distortion measurements of various capacitors have been posted on the internet with oscilliscope pictures. One can hear it & see it. And, some may actually like it, but I never read that anywhere as applied to high-end audio playback.
Edit- Being new here, perhaps this Fisher site is more about restoration vs modding for higher performance. When I finish the Fisher 400 mods in the FM tuner, audio & PS sections, I'll document the results in Tube Audio section of the AK site.
