fisher 400 aux input impedance?
head.banger
would like to know if the fisher 400 would match well with a denafrips ares 2 dac with rca output impedance of 1215 ohms?
does anyone know the input impedance of the aux input on a fisher 400? this fisher has many of the mods/updates done on it that are suggested in this forum.
thanks
The output Z of the DAC is irrelevant; what matters is the specified load. That aside, the schematic for the Fisher indicates the AUX input to be well above 100KΩ. No solid state unit will have difficulty with that.
Jack
What he said, input Z of tube gear tends to be fairly high and solid state gear will drive it with no issues at all. Its the other way around that you might have problems with, the high output impedance of tubes working into the compartively low input impedance of solid state.
The possible gotcha is output level on the DAC. Its probably going to be a fair bit higher than the Fisher was meant to work with so the volume control will end up very touchy. If you can bump down the output level of the DAC it will probably be easier to live with.
