In later versions of the 400, Fisher changed to a silicon bridge rectifier when they became available, and made no other changes in the circuit when they did. A 400 volt 4A bridge is plenty capable of the required job, and offers plenty of safety factory. Between the change to silicon and today's higher AC line voltages, the DC voltage to the heaters will definitely be higher than the published value. As a result, I usually install a 2Ω 5W resistor after the bridge but before the first filter cap. This not only lowers the output of this supply appropriately, but also maintains the original peak current demand that the supply draws from the power transformer, to prevent additional loading on it. However, while this takes care of the heater voltage, you will also want to recheck the current draw of your output tubes, as adding this resistance will also reduce the bias voltage to the output tubes, yet they are still receiving an elevated B+ level due to the higher line voltages. Therefore, their quiescent current draw will increase, necessitating adjust of their bias voltage. If you install an IBAM or IBBM circuit to provide for individual adjustment of output tube current draw, that will automatically address this issue.
Dave
