With the unit UPSIDE DOWN, The Front of the Unit is to your Right. You have 2 wires from the balance control, and 2 coax wires from the Phase Inverter area. Black with a stripe (green), and WHITE with a stripe. Pins are 1-2-3 side wall to balance pot.
Front POT (closest to attachment nut.)
Pin 1 White wire from Balance pot.
Pin 2 Center lead of WHITE COAX.
Pin 3 Shield lead of WHITE COAX (Ground)
Rear POT
Pin 1 Blue wire from Balance pot.
Pin 2 Center lead of BLACK COAX
Pin 3 Shield lead of BLACK COAX.
Underneath is the leads for the loudness circuit
White is for the Front Pot
Violet for the Rear Pot.
The ends aren't too clear to see where they go as the heatshrink is all the same color, but you get the general idea.
And next time, TAKE PICTURES!
