Sony6060,
I see that the top 680uf is on the far side of the choke in your correction. Hopefully I have that correct.
Are that 680uf cap and the 10uf ASC cap tapping off the same spot and terminating at the same spot? Is the 10uf acting as some kind of bypass cap? I don't understand that part. Can you help please?
The top 680uf appears to be replacing C56 in your schematic? The bottom 680uf cap appears to be replacing C57c.
Then you're using a 30/30/30/30 can for C52A and C52B with each being a 60uf combo of two 30uf sections paralleled?
I'm just trying to triangulate your posts on the other page with this schematic to make sure I understand this. I'd like to try it.
Also, if I understand it correctly, you're substituting a 30/30/30/30 for C52A-C52D because the upstream ripple is now far less.
That cap that you changed to a ceramic cap before diode CR3 - what is its circuit function? I thought that was the death cap. If not, what is is?
I do not know how to express it different than as shown in schematic. Later version is correct. First version had wire going to 7868 audio transformers on wrong side of choke.
30/30/30/30uF was used because 40/40/40/20 was not available. I had no AC hum concerns because less AC input was being applied to the new filter with less capacitance thanks to the 680uF first caps, choke, then 10uF filter sections. The 10uF can also go to the ground vs top of lower cap. Either is ok.
CR3 is simply a transcient capacitor that shunts short term noise and high voltage spikes to ground vs thru the diodes. This adds some diode protection. The old cap may be subject to failure due to age so I changed it to new ceramic cap. I also believe the stock 600 volt rating a little on the low side, thus the 1000 volt rating of the new capacitor. Death caps are on the AC line, not B+. I removed the death cap and high value resistor from the AC line to chassis, but ran out of time to install 3-wire cord. If a two wire AC line design is present, the death cap should be installed from the neutral side of the AC power line to chassis. Problem is non-polarized plugs can not guarantee which side is neutral. Thus, the three wire cord is necessary with death cap removed. The death cap can reduce noise in high gain preamp sections on two wire AC systems. I'll perform the grounding type power cord later as I have wood floor presenting very little of a shock hazard. A concrete floor with bare feet is a hazard.
