So true, well I found one I'll put it in Monday's mail.
Thanks a lot, merrylander! I appreciate everything.
I'm not sure what you mean by that. Mixing tube positions?P.S. label your tubes for each socket. Most likely your volume problem is created by mixing tube positions.
In the FM section the particular tube in a particular socket is important to preserve the alignment. You need to get each tube back in its original socket.
Really? I had no idea about that.
I used to mix up the tubes in my Fisher 500-c when I was a teen. I was getting that annoying ~400hz buzzing sound that will never go away.![]()
V1 thru V5 or 6 depending on whether your serial is below or above 48001.
The TUNER TUBES. All the ones in the middle row starting from behind the tuner and having a transformer tower between or next to them. 6ab4, 6ha5, 6au6, 6ba6, 6hs6
Print the attachment out. All marked in RED STAY IN THEIR RESPECTIVE SOCKETS. the 12AX7's can be rotated around With the exception of V100, thru V102. Mark them in RED ALSO.
Agreed! Thanks to everybody, once again!I'm just a spectator in this thread, but it sure is great to see the collective wisdom (and generosity) come together to help out a new member. What a nice place!
