I'm trying to finish the refurb of a Fisher 440-T that I worked over a few decades ago. It had some problems that remained, but I think I have fixed each of them, except for two.
Fisher 440-T (transistor) SN: 34xxxB. I have the service manual beginning SN 20001, which seems to be the appropriate one, but there's no mention of the B at the end. Anyone know what that means? I've found a couple mistakes in the service manual and can share them if anyone cares.
The amp and preamp all work now, and the tuner does FM mono just fine.
Remaining problems are: no indication on the signal strength meter and no FM stereo output or "Stereo Beacon" lamp lite.
Because the signal strength meter signal comes from the IF strip, I'm starting there, but I've run into a couple questions. Under IF Alignment, third paragraph, it says, "AdjustZ303 (Bottom core)..." but then in paragraph 5 it says to adjust "bottom core of Z303". The top core of A303 is not mentioned anywhere, so I suspect that one of these should refer to the Z303 top core. My GUESS is that paragraph 3 should refer to Z303 top core. Looking at the schematic, there are up and down arrows next to each IF transformer winding. I'm GUESSING that these arrows are supposed to indicate which cores are on top and which are on the bottom. Because I suspected a problem in Z303, I've had it apart, so I know that the secondary is on top, not on the bottom as the schematic arrow seems to indicate. Am I completely wrong about what the arrows mean?
There was no problem inside Z303. I even measured the two capacitances, which each came out to within 10% of the indicated 47 pF. There were no shorts anywhere and the included diode was still good. I've read that these can have "SMD" or Silver Mica Disease, but I'm not sure what else I should do to check for that. If someone would care to explain exactly what SMD is and how to identify it, I'd love to hear from you.
I have checked all the components leading from the IF strip to the meter and they are all good. When I check the IF output pin, TP302, the voltage there is zero, even with a strong local station. If I inject a voltage there with my VOM, the signal meter deflects.
I'm hoping that getting the signal strength meter working will bring the multiplex back to life, but I don't think there's any point in worrying about that until I get the IF fully working. If it doesn't, I'll deal with that later, once I get some advice on the IF strip problem.
Thanks for any insight you care to offer.
