MrVelvito
Happy Holidays everyone!
I'm a newbie to this hobby and am enjoying it a lot, but I could really use some guidance on how to proceed.
BACKGROUND:
I rescued a 500 mono chassis out of an old console that was in terrible shape and quite moldy. To this chassis, I:
1) recapped it
2) put in a 3-wire outlet cord
3) put in a thermistor to limit inrush current
When I powered up the unit (slowly on a variac) before the recap, one of the 5881 output tubes got much hotter to the touch than the other. To my pleasant surprise, the unit worked and I got sound out of FM. After the recap, the same output tube ran hot.
I swapped the two output tubes in the chassis and the one that ran hotter in the old location ran hotter in the new. Soon after the swap the sound faded away and now both 5881s test bad for emissions.
I purchased new Sovtek 5881s but am hesitant to install them for fear of burning them up, too.
The schematic I have shows that output tubes (KT66s/EL34s) running with a plate voltage of 400V and a grid voltage of -37V. Before they died, my 5881s were running with:
Plate on V11: 521V
Plate on V12: 515V
Grid on V11: -24.4V
Grid on V12: -23.5V
Which seem too high for both the plate and grid according to the 5881 spec sheet (if I'm reading it correctly).
ADVICE NEEDED:
So... does someone know what the plate and grid voltage should be for the 5881s in a Fisher 500 mono? If I'm running too hot, what can I do to fix the problem? Other recommendations?
Any help would be greatly appreciated!
TIA
-MrV
BACKGROUND:
1) recapped it
Plate on V11: 521V
Plate on V12: 515V
Grid on V11: -24.4V
Grid on V12: -23.5V
ADVICE NEEDED:
TIA
-MrV
