Fisher 500-T MPX Decoder Issue
I pulled the PEC's (PC50B187-38......PC402 & 403) from both boards (separately to keep them apart) and got the same readings +/-5%. So I'll give you one representative reading set.
Pin...................CAPACITANCE.......................RESISTANCE
1-2.....................6.35nF..................................OL (out of limits or open)
1-3.....................0.175nF................................13.36K
2-3.....................7.74nF..................................OL (out of limits or open)
All 4 were so close it was astonishing. resistance varied between 13.04 and 13.49K ohms. Capacitance was similarly close.
Hope this helps Ron
Larry
Dave - I have since replaced the tantalums with film caps. The left channel still comes up slowly in stereo and has some distortion. It is not an issue in mono; no delay, no distortion.
Larry - thank you, I really appreciate your efforts! Well, I guess I need to pull those 1500 pF caps out and put in 6800 pF...
If there is no DC appearing at the output of the multiplexer board -- and there is a DC return path to maintain a ground reference on the output side of the left channel coupling cap -- then it may be time to peek inside the chopper networks. If the left channel chopper can be removed, it should be pretty easy to verify the condition of the resistors and diodes within the chopper using your ohm meter. That's about all that's left.
Dave
