Fisher 500 TX
HalfKidding
Hi guys, im new to fisher equipment and picked up a Fisher 500 TX
Upon looking up information on it and looking around on that one auction site. they are selling for over $450.
What is so special about this particular Fisher receiver that demands this kind of money?
Thanks!
It was FISHER's TOTL Solid State Receiver from 1969 to 1971. It and the Export version 800-T(which had multi voltage transformer, and the wired remote standard, optinal on the 500-TX) were roughly 65WPC RMS, Had AM/FM Stereo/ Manual Tuning, PRESET TUNING via 4 Varactors, and Auto-Scan Tuning. This was big stuff in 1969.
I've got 2 of them. Both with the optional RK-30 wired remote. Very good tuner, and the amp section is all silicon.
Thanks!
however i dont think the 500 TX i have is working properly. i would not describe it as buzzing but theres noise in the headphones when i listen to it. how can i diagnose the problem?
Is the noise volume dependent, meaning does the volume of the noise track with the volume?
Is it a low pitched noise, like a hum? or is it more like snaps, crackling, and or pops.
Does it do this in ALL selector positions (AM/FM (both mono and Stereo), Phono, Aux, Tape monitor, etc., or just one position.
i dont think its volume dependent. it is more like a hum / buzzing. not popping of cracking.
i will try to see if it shows up in all modes (AM/FM/phono and such)
Rebuild the Power supply. All the caps, install 1n5406 diodes or UF equivalents, and check the 2 zener diodes for correct output voltage. One of them is soldered across what looks like a heat shield. It's HOT electrically, so Watch it when probing. A hunk of heatshrink tubing on your meter probe (all the way down to the tip) will help with slips (and we ALL have slippped at one time or another).
NOTE: The two LARGE CAPS laying on their sides have a lead on top soldered to the board. This is JUST FOR STABILIZATION! You don't need it with new caps. Make a bed of hot glue and press the new ones in, making sure you have enough lead length to go into the board holes. I normally solder them in 1st using as little as possible lead to clear the bottom of the board. When everything cools I bend the caps over and glue them down.
source: http://www.alliedcatalogs.com/html/1970-290/hindex_050_001-050.html
Pre FTC power specification regulations (of 1974)! 165 watts stereo IHF Music power (not exactly the same as "peak") and probably into 4 ohms. Probably 50 to 60 watts "RMS" (i.e., continuous) into 8 ohms at a reasonable (1%) THD in "modern" terms.
How hard is it to recap something like this? My soldering skills are very limited. Is it worth my time to get this done?
I recapped a Harman Kardon Citation 21 preamp, all electrolytics except the main power supply filter, approximately 50 caps total, in 2 days. Nothing else was done to the unit other than disassembly to get to both sides of the main circuit boards. This involves using a very good solder sucker, one with the spring loaded sucker, not the stupid squeeze bulb on top.
A quick look at the 500-TX shows 34 electrolytics not counting the main filters. Those would take a bit of time because some rewiring and mechanical work would probably be required. Additionally, if the circuit boards are like those in the 600-T, the connecting pins would benefit from being replaced with better terminals. I'd estimate 3-4 days.
Yes it can be overhauled, and it's worth it especially if the tuner presets, andtoscan are already the au wrking. However it really isn't a beginner's project. If you use the model car difficulty level markings, I'd give the 500-TX an Intermediate to ADVANCED Level ratingI'd pt it off to the side for now, and practice on a few Bthe uild your skill level at asy to work on and bOTL unitls that are e.
I got the Fisher thinking it would be my main receiver. But since my repair skills is limited i will let someone who appreciates it breathe new life into it and move on to something else.
Thanks for all the help guys!
