OK, not quite precisely for a 500B, but thats what the parts are from. I'm using the multiplex adapter from a 500B stand-alone, and I have it fed into an EM84 eye tube from the appropriate connection spot on the unit. What should the eye tube be doing exactly? Looks like its acting like a sound level meter. I'd expect it to work more like a signal meter and be steady rather than fluttering around like it does. Is this likely a bad diode in the detector circuit, or wonky caps in that area?
http://oldtech.net/Fisher/500B/schemmpx.gif
is the schematic I'm using for mine.
