NYListens
CBGB & OMFUG
Well I finally won a tub receiver on e-bay. It is in the mail and should be here in a day or two. I am eager to start re-capping it and the rest of the restoration process. However, I have read on here that there are restoration packs available from several sources. These packs seem very expensive for what you get. I assume all the caps and everything else would run $30 at most. Is there a list anywhere available of what you need to replace? Does it make sense for me to order one of these with full instructions, as I have never done this before? I have had some experience soldering, but only have basic electronic knowledge, such as what most of the components do and what their symbols on a schematic are.
I don’t know what other modifications need to be made, other than reading that the rectifier bridge needed to be replaced (I don’t know what that is.)
. good luck!:thmbsp:
