fisher 500b output transformers same part # ?
Eric Julius
I have a bunch of fisher 500b output transformers trying to sort out for someone. Does anyone know if the right and left output transformers of a Fisher 500B are same model?
Some tube amps (not many) use 2 slightly different model OPTs for Left and Right because the wire outlet holes are different even though impedance is identical.
I have the same problem, and am glad to see this question. Seeburg used two different part numbers for the output transformers on their stereo tube-amps, and the only reason I can see is the mirror-image fan-out of the output taps. The terminal strip that they are connected to has a single common screw for both channels right in the middle, and the highest power (lowest impedance) output taps are at the far ends, with increasing level taps in between... i.e. like this:
16w 12w 4w 2w Comm. 2w 4w 12w 16w
Left channel Right Channel
For those who may not know about jukes, they did this so that external speakers could be connected and the power distributed evenly (or made higher or lower for volume balancing) while not overloading the amp. Instead of telling the installer all about impedance and "ohms", the only instruction they had to impart was to not have the total "wattage" of all taps used on a channel exceed the capacity of the amplifier. No complicated Ohm's Law or "parallel-series" circuits to confuse a fellow who may not have finished high school!
--Bob
