Fisher 500c Odd square wave behavior
nerdorama
AK member
I'm working on a Fisher 500c for a friend. Did the first power up with tubes yesterday. Sine waves at 1kHz passed without any apparent issue but square waves are pretty distorted. A huge overshoot spike, very narrow, and the a rising top until the trailing edge. Anyone seen this before? It is happening in the power amp section as driving the "amp in" jack gives the same result. The tubes are all new, TS 7591 and JJ frame grid 12AX7. I have installed an IBBA board and made the modification to the phase splitter per one of Dave Gillespie's articles.
I posted in the Fisher forum but thought I might get more coverage here since this seems like a general tube topic rather than just a Fisher question.
Thanks,
John
Yes. I didn't have time yesterday to investigate any further and I won't have much time today. Probably should be down in the shop instead of reading here.
another thought, and I'm not looking at the schematic so I may be dead wrong on this one
does this ground something other than the 0 / C terminal ? I know some ground the 4 ohm tap, and if you take readings using a scope grounded to C it basically shorts the output stage and gives really funky readings. If this one grounds the 4 ohm, ground the scope to the 4 ohm and use the 16 ohm for the scope +.
Great question. Yes, in fact it does ground the 4ohm tap. Great call. I'll give it a check a bit later after some errands.
Thanks so much. Didn't even think of this.
Well, now it seems I have a bigger problem. Brought it up on the variac to make another test and started getting a snap or clicking sound which appears to be from somewhere up front near the volume pot. The unit is upside down so can't see the top. The 7W resistor that feeds the output tube screens started to smoke and once the power supply had drained down it was really hot to the touch. It was working yesterday, at least sine waves looked quite good. Now I have a patient again. I'll pull the output tubes and bring it up until the bias voltage is about normal. Could be an arc inside one of the tubes but it only sounded like coming from somewhere else. I'll run them across my tube tester and see if any of them test poorly.
John
AC switch arcing, which means a repeated hot power cycle? Can this make screens draw excessively?
I suppose it could be the switch. I've been leaving it in the on position and using the variac to bring up the voltage. It could still arc if it is bad condition. Could be more than one thing going on here. I'm a little hesitant to turn it on again until I figure out why the resistor got so hot it smoked. I'm letting it lie until tomorrow. I'll test the tubes first in case something shows up with them. Appreciate the help.
I suppose it could be the switch. I've been leaving it in the on position and using the variac to bring up the voltage. It could still arc if it is bad condition. Could be more than one thing going on here. I'm a little hesitant to turn it on again until I figure out why the resistor got so hit it smoked. I'm letting it lie until tomorrow. I'll test the tubes first in case something shows up with them. Appreciate the help.
Testing the output tubes is a good starting point.
John
We normally replace that 7W resistor with a 10W since they run pretty ragged and are known to fail.
Yep, Most of my Fishers that have that resistor show heat stress. Recently I restored a Fisher 500B that had that resistor blown. Having said that though, it shouldn't be smoking, so there is something going on that needs figured out. Maybe a bad cap downstream or a short of some kind.
Something, I think, has failed. The amp ran just fine for several hours the previous day while I momitored bias currents and voltages.
i have replaced the electrolytics, new output coupling caps, added 10ohm cathode resistors, screen stability resistors, reworked the phase splitter per DaveG's article, reworked the bias supply and added the IBBA board, etc.
I'd install screen resistors and check the C91 A,B,C,D sections or just replace it. There is nothing else connected to that draw other than the C91D and the screens.
After restoring a 800-C years ago, about one hour into testing that big resistor started smoking and failed, I have upgraded and replaced them ever since that happened on restorations.
Maybe it's just the resistor rating. I'll have to see if I have a higher rated one or maybe a pair I can use in series or parallel. It does seem a little odd that it would fail when it has lasted so long. Haven't had enough coffee yet to start in on it.
It's known to fail, and I have had many units come through here that already had it replaced. Dave Gillespie stated that it is run on the ragged edge using 7 watt rated, and I have seen many discolored by heat. I'm not saying there couldn't be a problem elsewhere, Just that most of us replace those with a 10 watt.
Did a bit more testing. It isn't the power switch arcing. I disconnected the switch and hot wired the amp. Still clicking. I monitored the voltage across the 1.2k 7W resistor. It's generally ok but whenever the arc/click happens it shoots up. The click still sounds like it's coming from the front corner of the amp in the area of the power switch. It also does it with the output tubes removed. Guess I'll start pulling other tubes and see if I can get to go quiet, or not.
A wild guess, but I don't suppose it's the (eek!) speaker selector switch? Possibly shorting and causing the output transformers to misbehave in some way? I'd say it sounds like an arcing can cap but there aren't any there.
