Fisher 500c Relay?
friendlyvolc
(Note: I posted this first on Tube Audio, but thought this might be a better place...)
We've done a full restore on my beautiful Fisher 500c, which sounds fantastic now and is pretty much minty fresh. The only issue we've run into is that the relay that controls the Stereo Beacon light was fused and needed to be removed in order for stereo to work properly. Right now the Stereo Beacon light is on full time, regardless of the dial position or if I'm on the phono/aux settings.
The part that was removed was this one in the schematic:
RL1 “Relay” and part # K50314
Apart from raiding a junker (which I will do if I can track one down) does anyone have an idea on a comparable modern part that might function within spec? If we can find one from a parts unit, we'll do that, but I thought I might do a shoutout to see if anyone has any "illuminating" ideas...
Welcome to AK. The Stereo Beacon light works off a relay that clicks on and off when a stereo signal is received. Your in a great place for help and someone will post on this, I'm no expert either and still learning as well... stay tuned and again, welcome Al
The other thing that was done was install a NOS Fisher 6G5K to replace the original one that was slightly out of spec. I'm led to believe the 6G5K controls the relay and must be within 10% of spec to work properly.
But the relay was already removed/by-passed at that point, so it won't make a difference until we get a new relay. To anyone's knowledge, is there a go-to source for boneyard 500c parts?
Can you separate the contact's without one or the other separating from it's mount?
If so(I've done this on Automotive 12V relays with pretty good success) you might take some 400-800- 1200 grit wet/dry sandpaper, cut a strip or two about 4" long by 1" wide. Fold over or cut and glue two strips together. Then pull the paper thru the contacts gently and in one direction (do not scrub) multiple times to get rid of the arc'ed over spalling on the contacts. Using double sided increases the chances that they will be 1/2way flat against each other when the relay is closed. Start with the 400 for heavy removal moving to 800 for smll final removal and 1200 for final touchup. Use a magnifying glass to inspect and plenty of DIRECT light.
My understanding is, The 6GK5 is nothing more than a switch if you will. It's fed off the the 160 volt power supply tap marked "C" on the schematic , and "D" which is the Multiplex Indicator circuit. I'd start looking at the "C" and "D" voltages to the tube and the pin voltages at the tube. I've got a couple of 6GK5's that are damned near dead and they work fine in my 800-C's for the stereo lamp.
If the contacts fused, it's probably due to a short in the lamp circuit from the power supply thru the lamp and then to the ground at the relay (the contacts are normally open ie: no light, then when the relay coil is energized from the 6GK5 the contacts close and the lamp is grounded, causing it to light up. Also check the voltage at point "E". It should be no more than 6.3vAC.
I'm thinking your unit had a short in the lamp or lamp socket, which caused the relay contacts to fuse. I don't think the 6GK5 had anything to do with it, other than pulling in the relay when directed to. This would have also affected V1-V2-V3-V4-V5-V6 and V18 heaters which are also on the same transformer branch.
I don't know of any parts depot's for them. Ebay or putting up a subscriber ad in BARTERTOWN (you have to become a subscriber. Cheap at any price. And no fees for sales either.) Don't limit yourself to the 500-C. The 800-C used the same RELAY.
Or figure out the voltage/wattage of the relay coil, and the ratings on the contacts, then purchase a new relay with similar specs. You'll probably end up having to make a mount as most of them are either thru hole mount or pc board mount.
Larry
The relay is what was commonly known back in the day as a "plate" relay. Such relays are only different from modern relays, in that they have (by comparison) a very high impedance coil, that is rated in required coil current flow to make the relay operate; not required coil voltage as virtually all modern relays are. A very quick check didn't return any sources for such relays today.
From schematic information, the relay will likely have approximate specifications of a 5 ma coil, that should have a resistance of about 6000 ohms.
Good luck with your search!
Dave
Dave & Larry: Thanks so much... I'll let you know what we work out. I'm sure there will be a little trial and error. Apart from this flaw, the unit is really stunning, so in my OCD way, I can't rest until it's 100%. I figured the 800c would be identical, but probably rarer. Do you think it makes the most sense to try and pull one from a parts unit instead of fabricating/adapting from modern parts?
You'd be better off with a parts donor, vs trying to retrofit and jury rig a relay that may or may not work. Actually the 500-C had lower production numbers from what I've been able to find. Look at EBAY. For every 500-C, you've got about 3-4 800-C's out there competing for buyers. The 800-C and 500-C is basically the same unit. The main difference is the AM BAND on the 800-C which the 500-C lacks.
Look for places that specialize in "old radio parts". If you have the old relay, look for identification stamping, etchings on the body. Write them down.
One place you might try is Old Radio Parts - Capacitors and Dials for Antique Radios
www.oldradioparts.net/ He's got tons of pots, attenuators, etc for old radios. Wouldn't hurt to see if he has any relay's.
Great info. I've started to PM anyone on Ebay who lists pulled 500c/800c parts in hope that they've got a junker stashed in the back....
