Fisher 500c Right channel humming, probable ground loop problem?
bberkom
AK Subscriber
I have had a slight hum/buzz in my right channel speaker for some time now when playing my turntable, and I am really wanting to get it sorted. I just bought and set up a fisher 500c to replace a cheap harmon kardon stereo reciever, and the hum has been present in both receivers when using my TT.
With the fisher, when I use the integrated phono preamp, the hum mostly goes away, but there is a much quieter hum in both speakers. I had been using a parasound z-phono preamp with my harmon kardon and was planning to do the same with the fisher. But if I run through the parasound into the aux input of the amp, the bad right channel hum persists. The hum is not present if I hook another source into the aux input (CD player, 1/8" input to ipod). So I think there is a ground loop issue with the parasound or with my TT.
I think the RCA cables I have been using are too long, so I am going to grab some shorter ones. My Turntable is a Pro-ject Debut III with an Ortofon 2M Red cart. Is there a shielding issue with this TT and cart combo? I also have the pro-ject speed box. I have tried different wall outlets as well, but still thinking it could be a problem with power since I didn't have the hum in my old house.
Just wondering if anyone had any suggestions. I am fairly certain it isn't the fisher amp since the hum mostly is gone once I remove the parasound preamp from the system and when using other devices in the aux input. I may just have to use the preamp in the fisher, and it has been recapped, so that is good.
Sounds like the TT, cartridge and/or their connections could be the problem. Try the cables first.
The new, shorter RCA cables made no difference. I check connections at cartridge and from tonearm to the RCA and ground wires. Everything looks fine there. I did, however, connect the ground wire from the TT to the chassis of the fisher instead of the phono preamp, and the hum is very noticeably reduced. So much so that I can live with it.
I am also going to try moving my internet router and wireless router from the same entertainment center and hope that helps. It's definitely a grounding problem, but it seems to be a combination of small factors, as usual. I'll just keep plugging away.
Too many variables for me! Now I see house makes difference! ; - )
Many complaints on this table with noise problems add word ground to search and see even more
Big question many things possible
I hope you get it solved! ; - )
JJ
Thanks for the help. I am fairly certain it isn't the Fisher amp. Probably a combination of small factors adding up. I think I am starting to get some improvements, but it's probably just what I get with an eight-year-old, well-used entry turntable. At least it gives me something to do.
Troubling though that confined mainly to one channel
You watch that video? Yours buzz like that?
JJ
JJ
Yeah mine buzzes about like that. Also, it is in both channels. I am just an idiot and didn't closely listen to the other channel once I noticed it. The buzz is reduced now that I have the TT grounded to the Fisher instead of the preamp. I also noticed that it is slightly reduced when I touch the metal tonearm.
Little noise like tube rush yeah but metallic buzz not happy
Try running table ground to pre amp and run a wire from pre amp to Fisher just to see if gets even better
Still having trouble understanding though you said it did same thing with HK?
Anyway enjoy! ; - )
JJ
