davstev
Well-Known Member
HEADPHONES are tapped off the speaker leads, before the speaker screw boards, with resistors inline to drop the power so the headphones can handle the power. 330ohm 1w dropping resistors at the headphone jack. One thing to check with headphones is balance. Turn balance all the way to right or left. If the sound follows to the same side, you're ok. If the sound tracks to the other side, no problem. Just reverse the resistors on the leads at the jack. How many ohms are the drivers on the Grado's. I find that a low impedance driver on my 400 and 800c tend to break up and distort faster and easier than a high impedance headphone. My son bought me a pair of Dr. Dre's for Xmas. What a friggin waste of materials on their part and $$ on his part. I played them for about an hours then sent them back. Brought out my old reliables. I have a pair of PRO-4A's I bought as high school freshman in 1969 (260ohm), a pair of Koss SP/3X cups (the frames broke up about 5 years ago) that I bought in 1974in the Navy, that I modded into a pair David Clark Military Ear Protector headset cups, and a New pair of Pro-4AA (260ohm). All 3 handle everything without problem.
So check the channel orientation and then clean the contacts in the jack with DeOxit and Q-tips. As it's an open design you can clean it after soldering, before closing it up. And check the value with a meter of the 1w 330ohm resistors. They are 10%, but I'd replace them if they are 5% or more high or low
Thanks, belatedly for this excellent post.
The Grado's are 40 ohms impedance.
