AK577
Hello
I am in the process of rebuilding the power supply board along with the others. This is my first actual project.
I bought this receiver couple years ago and it never worked correctly. The last three weeks I’ve been researching everything and I attempted to fix it. I found a shorted output transistor and two bad resistors. I replaced those and it actually started working for the most part.
It had distortion when turned up, and my scope indicates it only has around 30 watts rms before clipping. This was at 1kHz, one channel driven at a time. Both acted the same way.
I bought a kit on eBay that I know I overpaid for, but it supposedly has all the capacitors that need to be changed along with instructions. I’ve removed the power supply board this morning to replace the capacitors and found something that isn’t factory and I have no idea what to do.
Something is soldered to one of the transistors Q972 I believe. It connects to one of the pins and goes back to ground.
I am not sure what to do, I tested the transistor and it tests okay. Any help would be greatly appreciated!!!
