retrokid 52
Member
:scratch2:Hi Fisher friends
I found 4 NOS RCA 1N2326 diodes used in the conversion of the bias pots on my hybrid 59A amp.
Larry was great and emailed me the specs for the conversion of the 49A. However ....when I crossed refereced the listing for the resistors in that circuit that the modification called out to REMOVE, those reistors are of different values between the 49A and the 59A.
Would that indicate that the resistors that are called out to INSTALL for the coversion actually different for the 49A and the 59A. Both conversions use the RCA 1N2326 diode.
Does anyone have a Service Manual for the 59A that has the "Modification"
listed on the page for the amp?
Boy... I do not want to make a mistake and take out all of the germanium transistors!!!!
Everything is working beautifully now....should I just leave well enough alone?
Thanks
George
Thanks
George
:thmbsp:
