AnyDayNow
I’m trying to learn how my Fisher 70A tube amp works, and I chosen to work through the excellent ‘Elmer education’ offered recently by Mark on the Blueglow Electronics YouTube channel in which he walks through a Fisher 30A amplifier. I believe the Fisher 30A (1959-) is an example of a ‘Williamson’ type of tube amplifier; I’m not sure if the Fisher 70A (1954-) is or not. What I do know is, that while the 30A has only a single stage of amplification; the 70A has two stages of amplification.
They also have different output tubes. The 30A uses EL84 tubes; the 70A used 5881 tubes.
I’m just having trouble analyzing the Driver stage in the 70A amp design; the 30A amp has no driver stage.
I’m hoping a member familiar with Fisher amps, and tube amp design generally, can point me in the right direction for further study.
For the curious, the 30A uses a single 12AX7 for both the AF Amp and Phase Splitter functions and then straight into the EL84 output tubes.
The 70A uses a 12AT7 to serve the same functions, but the takes both out-of-phase signals from plate and cathode into the grids of a 12AU7 before sending opposing signals of the plate and cathode into the grids of the 5881 output tubes.
Since the gain of the 12AT7 in the older 70A amp is not as great as the gain of the 12AX7 in the newer 30A amp design, I figure some sort of amplification is taking place; but what is the 12AU7 contributing? Does the 5881 tube require a driver stage?
Enquiring minds want to know.
Also, can anyone confirm that the 70A still a Williamson design, or is it some other type?
Note: I can attach schematics of both units if rules permit (I believe they’re both in the public domain.)
