Triplett hooked up to TP3 and the input goes to tube shield V2 which is electrically taped to isolate it from the chassis and measures infinity. Chassis on its side supported by 4 business cards on the transformer and wired to shelf with wire. Volume control sprayed with Deoxit D5 and cycled 100 times. Sencore SG165 is hooked up to the tube shield V2.
Z2 top from 19 to 19.5 smoothly after warmup altered slightly to 19.1 buy since bottom is inside tuner cage must remove tuner cage to proceed. Sencore SG165 works well. Peaked bottom of V2 nicely, uses hex
Z3 peaked nicely from top and bottom. Uses hex
Z5 peaked nicely from top but locked on bottom. Uses slot not hex
Z6 peaked nicely from top and bottom. Uses hex
Z7 peaked nicely from top and bottom. Uses hex up to –33.2 volts now! Replace tuner cage on bottom.
