dsndblm: Ummmm....... u might be in luck. I'll have to check and see. Will let you know tonight or sometime tomorrow.
dsndblm: I've got an extra X101B faceplate if notdigital doesn't find one
I'm pretty sure there are solid brass (202-R for example) and brass plating over steel. My X202 needs a faceplate refresh and is brass over steel - I actually polished through to the steel on one edge while experimenting. I think a service replating to brass and rescreening onto the brass faceplates would be a hit.
My 80-AZ has an engraved brass faceplate!
Thanks for trying!Sorry ds, found the face plate and it has a phone jack.
Larry,Guys, IIRC the Center channel switch was replaced in situ by the headphone jack and FISHER just renamed the hole in the faceplate. At least this was the end result of a discussion of another amp with the same situation.
dsndblm; Is your switch cover ellipsed or circular? If it's circular measure on the sub panel from the bottom & top edge to the center of the hole, and then from both sides to center of the hole. Also measure the centers of the pots on both levels. This will give you centering measurements for the sub-panel and the faceplate. If the sub-panel for the headphone jack measurements are the same as for the center speaker switch and the switch cover is slightly smaller than the diameter of the headphone jack hole, I see no problem with it fitting. All you'd need to do is re-letter it.
LArry,
Joe is mostly correct in his post. However I will point out that the TA-600 was a 2 year model where the TA-800 was a 1 year model. The 500-S superceded the TA-600 sometime in 1960 and ran 1 year and then was superceded by the 500B/800B.
All Faceplates made for Fisher until the 1961 model line (500b/800B time) were stamped brass with silk-screened lettering on them. Fisher then changed over to a heavier (thicker) aluminium extrustion with silk-screened lettering. With the Solid State transistion a new style "framed" faceplate came out which looks to be a stamped aluminium billet. None of the FISHER Faceplates to my knowledge were engraved by the factory. There might have been a small cottage industry to fabricate engraved faceplates but if there was it was very small and selective in their products plus didn't last too long. The stamping/silk-screening carried on thru the 70's into the Black plastic crap age in the early 80's.
Larry
