Travis G.
It seems as if the automatic shutoff switch on my FIsher Futura IV console isn't working properly. I ordinarily keep it set to 'off,' so it just keeps running after an LP side ends, but now it won't work unless auto shutoff is set to 'on.' The knob actually has three settings -- off, normal and on -- but there are only two stops when you turn the knob, presumably off and on. I typically use the volume knob/AC off switch to power up and power down, but I've found my wife tends to use the auto shutoff for that.
I removed the turntable (Garrard Type A MKII) today for a re-lube, etc, and to retrieve the short spindle the fell beneath it months ago, and the 680A amp doesn't turn on at all with it unplugged. That may be normal -- I've never pulled the TT before (and it was a real pain to do!) -- and unrelated to the auto shutoff issue, but I'm wondering if anyone has suggestions/solutions while it's partially disassembled. Thanks!
