Fisher MPX-100 Power Transformer
drknstrmyknight
Addicted Member
Can anyone suggest a replacement for a Fisher MPX-100 Power Tranny?
What are the mounting dimensions? I may have one with 120 VAC (use a voltage doubler instead of bridge...) I would certainly add a fuse...
You should try digging into the old transformer. A lot of the time, the break is right where the winding was soldered, and it's easy to repair. I think the flux can eat through wires sometimes.
I have a Stancor PS8416 that has 250 V which would work for the B+ by increasing the value of R52 ,but you would need a second fillament transformer because the 6.3 volt winding is only 1 amp and the original had two fillament windings and need one with 1.5 to 2 amp 6.3 volt for the five tubes filaments
Mark
