Fisher mt-6040...?
NickQ
Just Some Guy
I have the opprotunity to pick up a Fisher Studio Standard mt-6040 (minus needle) for about ten bucks. I have looked here for info on this table, as well as Google and VE but there doesn't seem to be any info about this TT other than it's a direct drive table circa 1980. The only photo I found was this one of the service manual (below). I don't need another table, but should I pick it up for $10?
I love my MT-6225. If this is similar it is easily worth $10.
Howard told me that my table is a CEC with an Acos arm. Based on that pic and the model number I'm guessing that one is also. This knowledge should lead you to lots of good information. It did for me.
Direct drive, s-arm from 1980 means it's most likely decent. Probably made by CEC. Easily worth $10.
I don't know if I believe the 1980 part. My 6225 is from 1977 and this model has a lower model number and looks older. I would guess 72-75 era.
Don't go by the model number--that's seldom a reliable indicator. CEC was making these tts with the flat base into '82. Look at Radio Shack catalogs from '79-82 and you'll see virtually the same models by CEC. Early '70s tts had large, boxy, plinths.
