Fisher MT-6225 TT
t j
Scored this a while ago and am just trying to get it sounding good. The anti skate adjusting knob seems dead. It's just snapping back when I turn it. I'd love some insight, or a magic bullet, before I start opening it up...
-Thanks, TJ
Is this table a rebadged Micro Seiki? Headshell and other features sure look like it.
Can you find a service manual for the table?
I have no manual or any knowledge of this being a Micro Seiki. Rebadged by whom? Did Fisher have a partnership with Micro Seiki? So much stuff to learn.
I have one of these and when I would play it about midway through a record it would skip, well I found out that the tone arm side to side bearing was dirty. I had to take the tone arm loose and pull it out to get to the bearing. I did not have to detach any of the wires going through it because I was able to get enough slack in them to pull the arm out to get to the bearing.
The way to check them is to first remove the needle, second adjust the weight so the arm floats, third set the antiskate to zero and pull the floating arm to the area about the end of the record and when you let it go it should stay there, forth now when you add antiskate to it the arm should slowly move back to the rest the more antiskate you add the faster it will go. Mine when I would do this would stop right in the middle. I cleaned the bearing and the race with qtips and rubbing alcohol. I did add a little oil to them but was told later that they were supposed to be dry but it does not seem to cause any problems. After learning about this I perform this check on all of my newly bought used turntables. Good luck :D
Thanks for the info. What do you know about the antiskate knob? Mine doesn't seem to turn right. It snaps back to the same position. Is there a spring or gear in there that needs to be reset?
I can't remember how it got enough friction to hold it in place but I do remember having to fool with it. When you pull the bottom cover off I believe the adjustment is right there.
  • Like
Reactions: t j
