Another RS-2010 saved from the scrap heap, here are a few notes that should help someone (I hope).
This was a late model RS-2010 w/STK0080's and the extra 2SC1708 Pre-Drivers In Front of Q11 & Q12 as noted elsewhere above.
I used STK0080's from eBay, supposedly "Sanyo" OEM, we will see....so far so good.
This one took some time.....smoky !!
Issues:
- Q12 Shorted, Q16 Smoked, R44 Smoked (See Pic)
- Several Zeners Dead Shorted
- C09 Popped Open
- R35/36 & R59/60 - 2 OK, One Open, One 50% of Value
- R54 (Emitter Resistor) Open
Notes:
- Full Recap of Electrolytics - Most Tested OK, a few out of Tolerance
- Tested All Resistors > 1/4W - Replaced R44, R59/60, R35/36, R51-R54
- Replaced all Small Signal Transistors
- Replaced all Zeners & Small Diodes
- Replaced STKs
- Sub List Below
- Watch Pin Outs Q11 & Q12 - OEM is BCE, Replacement ECB (Flip It)
- Watch Pin Out on Predriver Transistors Piggy Backed on Q11 & Q12 - OEM is BCE, Replacement ECB (I had to sketch that one out)
- Dirty Volume POT Caused ~ 5% Signal Differential L/R Channel
- Final Pic Attached
Part OEM OEM PIN NEW New PIN
Q01 2SC1571HL ECB KSC1815 ECB
Q02 2SC1571HL ECB KSC1815 ECB
Q03 2SA1016K ECB KSA992 ECB
Q04 2SA1016K ECB KSA992 ECB
Q05 2SA1016K ECB KSA992 ECB
Q06 2SA1016K ECB KSA992 ECB
Q07 2SA1016K ECB KSA992 ECB
Q08 2SA1016K ECB KSA992 ECB
Q09 2SA1047 E ECB KSA1381 ECB
Q10 2SA1047 E ECB KSA1381 ECB
Q11 2SC2441E BCE KSC3503 ECB
Q12 2SC2441E BCE KSC3503 ECB
Q13 2SD438D ECB KSC2383 ECB
Q14 2SD438D ECB KSC2383 ECB
Q15 2SB560D ECB KSA1013 ECB
Q16 2SB560D ECB KSA1013 ECB
Q17 2SC2362K ECB KSA1845 ECB
Q18 2SC2362K ECB KSA1845 ECB
Q19 2SC2362K ECB KSA1845 ECB
Q20 2SC2362K ECB KSA1845 ECB
Q21 2SC1175 ECB KSC1815 ECB
QX, QY 2SCC1708 BCE KSC1815 ECB
D01 DS-442 1N4148
D02 DS-442 1N4148
D03 DS-442 1N4148
D04 DS-442 1N4148
D05 05Z12U Zener 12V - 500mW
D06 05Z12U Zener 12V - 500mW
D07 DS-442 1N4148
D08 DS-442 1N4148
D09 DS-442 1N4148
D10 DS-442 1N4148
D11 DS-442 1N4148
D12 DS-442 1N4148
D13 DS-442 1N4148
D14 DS-442 1N4148
D15 RD3.6E Zener 3.6V - 500mW
D16 RD3.6E Zener 3.6V - 500mW
D17 RD3.6E Zener 3.6V - 500mW
D18 RD3.6E Zener 3.6V - 500mW
