Brivan
Well-Known Member
I purchased a Fisher RS-2010 receiver that was in protection mode and discovered D11, D13, D15, D17, Q13 & Q15 were all bad. Prior to that I had removed the left channel STK-0080II since it showed 49 volts on the audio output. Also prior to my discovery of the bad diodes and transistors, I replaced both STK-0080II modules with genuine Sanyo modules, only to discover the receiver was still in protection mode with 49 volts on the audio output of the left channel STK module. At this point, I discovered the bad diodes and transistors. I will have replacements tomorrow and am hoping the STK left channel STK module survived. No smoke or funny popping noises when I last powered it up. I also had audio coming from the original STK modules when probed with an audio tracer, so I'm hoping the problem was strictly with the bad diodes and transistors (bu I somehow doubt it).
I used Quicksilver heat sink compound on my two replacement STKs since they make direct contact with the heat sink. When I pulled the amp board and STKs away after finding out I had other bad components on the amp board, I noticed the heat sink compound pattern behind the left channel STK wasn't making good contact with it. And I put a fair amount of torque on the mounting screws (keeping in mind I was tightening down on plastic).
From the common failures these modules seem to exhibit from overheating when installed in a Fisher RS-2010, I thought maybe the heat sinks were warping and decided to mill down the contact area where the STK meets the heat sink. It came out pretty good, I think.
The milled surface is not smooth like the original was, but it's even. My theory is that, with both the rear surface of the STK and the heat sink being smooth, the heat sink compound would compress into a thin layer at best, not allowing much for metal-to-metal contact between the module and the heat sink. With the rougher milled surface, the heat sink compound will be pushed into the "pits" and the STK and heat sink will make direct contact on the "lands". Just a theory - we'll see how it goes.
