Hello friends,
I thought it was time to start the upgrades on my Fisher X-100-2 and want to document the information and photos. I know there have been many such threads covering what I'm planning on doing but I'm not quite expert enough to translate the information in those other threads and apply them to this particular amp.
To start off, I will say that this Fisher was pulled from daily use and was sounding so great. It was a difficult decision to ignore the procrastinator voice in my head that said, if it ain't broke...but I felt that performing at least the safety mods to the unit now would extend the usable life and enjoyment of it. This seemed like a no brainer and maybe, just maybe, in the process, I might build up my nerve to go full on modder and install an adjustable bias circuit and...gulp...possibly EFB(tm) ala Mr. Gillespie.
I've got some questions now and will likely have many more down the road, so let me just recognize the fine people who have given me so much help up to this point. While I've learned a lot in the last year, I would be spinning my wheels much of the time if it weren't for all you guys and your expertise. Thank you so much for all the help I received last year during my Scott LK-72 restoration and in other threads along the way.
My plans:
1) Triac mod to prolong the life of the power switch. Please weigh in if you disagree but I believe this mod is pretty universally accepted as beneficial.
2) Screen stability grid resistors (with questions below)
3) Cathode resistor mod (also questions below). Even though I will only be able to measure each tube current at this point, I feel it would be beneficial to at least know if the output tubes are closely matched.
4) Hayseed Hamfest can caps are ordered and should show up soon. Someone in the past had wired in a replacement C1 without actually removing that electrolytic cap. From a thread earlier this year, larryderouin helped me figure out what was going on with that part and made a few other suggestions for component replacement and upgrades here:
https://audiokarma.org/forums/index.php?threads/any-fisher-expert-techs-in-the-pnw.890664/
5) Not sure if I need to change out the control grid resistors but they are 330K in this amp and I've read that others have changed them to 200K in other designs but I don't understand why.
This amp has seen some work before I found it, mostly coupling cap replacement and the power supply cap mentioned above. I also installed a CL-80 to help with the inrush current last year. Along the way I'll also rework ugly solder, clean up flux and tidy things up but, for the most part, this is a pretty clean example:
Again, during these updates I'll be continuing to read up on Dave Gillespie's EFB(tm) mod or at a minimum IBAM. I just see the absolute value in getting an adjustable bias capability in this amp to extend tube life and improve performance. I hope keeping track of my progress will be helpful to others. I know it will certainly be a help to me just having a reference in one place.
First questions are about the cathode and screen resistors. I believe I will be removing all the jumper wires connecting pin 3 (cathode) and pin 9 (screen) on all four output tubes which are 6P14P-EB's at the moment? I've sketched up a drawing showing what I believe to be the intention:
Does this rough diagram look correct? Follow up questions are about the resistors themselves, mainly, 1/4 or 1/2 watt? Metal film or carbon comp? And, lastly, I understand one end of the buss bar will go back to the voltage connections but what about the other end? By the way, as the amp sits now, I went through and measured voltages around the power supply and the output tubes and everything is inline with the schematic so, the dream would be to install these mods and keep everything working well just like it is now.
I'm not exactly sure how to wire up the triac or where to install it. The underside of this chassis is pretty shallow and if I want to mount it near the power cord it'll be a tight fit. Photos and questions on that issue coming soon.
Thanks for reading!
-Steve
My plans:
Thanks for reading!
-Steve
and you may find she has found a new spot for the Kenwood, and it'll be quite painful!
