So far it hasn't gotten too hot to touch. I don't expect temperature to be a problem. The materials I used should be significantly more heat resistant that it originally was. The failure I had wasn't caused by overheating, it was definitely water damage.
Today, I replaced one of the crumbling tube sockets along with several out of tolerance resistors. Amazingly, the switches and pots are working fine, and even the power switch is good. There's an obvious high water mark on the chassis. It's definitely not a an amp that should have ever worked again.
