goatropercu
Goon
Hello,
I have a Fisher X-100 that has no filament voltage at tubes V1, V2, V6, and V7. There are very likely other issues, but this is the first thing that stands out. Fella that gave it to me said it was blowing smoke and I believe this may have been coming from the 2.2K resistor in the power supply.
Voltages appear to be good at the rectifier V11, C27A and C27B, and the heater supply to the other tubes.
As far as I can tell I have 0v at C15A. Also, I'm not sure where the heck C16 and R52 are physically, nor can I put my finger on R61, but like I said C27 seems to be kosher.
I looked at the guts of another X-100 on another AK thread and it seems like my cans are wired correctly, as long as what I was looking at was wired correctly. I installed new hayseed cans thinking/hoping that C15 was malfunctioning and all my woes would be relieved, but I am encountering the same readings with the new cans. After looking at the cans more closely it almost appears as if someone may have already replaced C15. This new-ish looking can along with a piece of paper w/ the #3 on it inside the chassis are the only indication of previous "work" so far. Can't find any obvious re-work.
Below are some voltage readings taken with the amp on dbt.
C27-B: 345vdc (384vdc)
C27-A: 300vdc (320vdc)
**DO NOT SEE R61 across C27-A and C27-B?
C15-A: 0v
C15-B: 297vdc (265vdc or 285?)
C15-C: 300vdc (285vdc)
**pretty sure I had meter on correct terminals
**don’t see R52 or C16
Rectifier Tube V11 GZ34/5AR4 (ON DBT)
2: 5vac (5vac)
4: 540vac and climbing (across 4 and 6 730vac)
6: 540vac and climbing (across 4 and 6 730vac)
8: 345vdc (approx 384vdc)
I’ll do some more studying and snooping, but any help identifying why my four 12ax7's are not glowing is greatly appreciated.
Thank you for your time.
C15-A: 0v
2: 5vac (5vac)
