Ok here's the story.
I bought a scott 299 in semi rough condition off ebay.
I got sent to me a mint fisher x 100 c instead.
Although it's not as pretty as the scott i made a deal with the seller to keep this unit.I like fisher's as i also own a mint 500c.
I proceed to buy a variac and succesfully reform the caps.
It plays for five minuits and then one channel goes south distorting.
I then recap the thing with russian teflons.a pair of russian k 40 pio's and two auricaps.I also replace the under chassis electrolytics.
What i get is simply the best most detailed amp i have ever heard.
It's rated at 24 watts but it felt like 50!Great in every way.
I used it like this for 3 months then i smell something funny.Metalic.
I know something is going wrong most likely the can caps.
I keep useing it any way.I was in denial.
Then i see smoke.Yeah i know i'm a dumb ass
I then go buy 3 can caps and try to parrallel two of them for the power supply.Well you can't parrallel can caps so i get blown fuses.
I try under chassis caps.I get blown fuses.
I find two 250 uf 250 v caps to replace the 200 uf 250 v caps that were stock.
I rewire everything perfect.All new cans all wired right.I have a nice pic.
I get a blown fuse.
I seriously lost it today.
I'm getting afraid to work on it anymore.
What i'm thinking is i might of heated up the high perfrmance fred diodes i was useing.They might be dead as i had to solder and resolder them a few times trying different parts.
Would this blow a fuse or just not turn on?
Here's something else i was wondering when the can caps went south there was a wire that burned but not near the cap.
If i rememeber correctly it runs to the other under chassis electrolytic.I taped it up with electrical tape.
Does or could this indicate another problem a wire burning away from the blown can caps?
What should i do now?
I'm going to get the schematic and trace everything.Just to make sure.
I burned a few wires underneath when i was useing a less powerful soldering iron.I taped all the burns up just to be sure maybe i need to replace those wires?
The first time i fired her up i got power to the tubes at 70v.
Now i just get burned fuses.
Oh just two clarify this amp stock uses 2 200 uf 250v can caps wired in a voltage doubler circut.
The other can cap is a 40 40 20 if i remember correctly.I have a 40,40,20,20 can cap in there now.One 20 uf section is not used.
The 2, 200 uf 250v power supply can were replaced with 2, 250 uf 250v cans.Made for voltage doubler's
I get a blown fuse.
