MFP4073
I recently picked up a pair of XP-10 as a project to run with my MC30 monoblock amps. I have always liked the consolette style of these and when a pair turned up locally I decided to grab them. At first listen they seemed to have all the usual issues, lacking highs but surprisingly the tweeters are still working. My initial intention was to clean up the outside of them and re-cap the crossovers. When I got inside I found that the original crossovers appear to have been modified and the woofers had been replaced with HH Scott 197B units. I re-capped what was there. There was some improvement but it just was not sounding good.
I was going to install a ready made X over by eminence but could not find one that had the crossover points I was looking for so decided I would give it a try and build my first crossover. I have rebuilt a few McIntosh amps with good success so I thought the crossover would be attainable. The science of these things confuses the hell out of me! After much reading I used on of the calculators to come up with a second order, band pass, butterworth design. It is simple and not optimized but I am giving it a go anyway.
The woofer is the 197B mentioned above, the mid is original, and I am replacing the tweeters with Morel CAT30's. Crossover points I selected are 300hZ (up from 200hz original) and 2500hZ (original). Anyway I'll see how it goes. The first crossover is almost done. I just need to make the connections for the tweeter.
Other speakers I have are a pair of 1960's Electro Voice Marquis that I reworked and then installed Crites X8 / X36 crossovers into and a pair of 1990's Boston VR-975s which are still my favorite of what I own. My fingers are crossed that the XP-10 sound nice! I wanted to share and will give an update once I have them working.
