bradscoolio
Heya Fellas'
Ground your pre-amp to the ground lead of the turntables power lead, the end that plugs into the rear of the turntable (I just wrapped a cable around it and forced it in
), as well as the regular ground post.
There must be a resistance between the ground on the power lead and the ground post causing a potential difference. (To my understanding, can't remember how it all worked)
I know this table is pretty renown for it's shitty hum ground loop issues, of which I've suffered for over 6 months with mine. Just wanted to let you know how I fixed it, in case this works for you too (there's apparently a few fixes going around, none of which worked for me).
I tried to find a thread where there was a whole bunch of fixes compiled into one OP, but I can't seem to find it. So here it goes.
Hope this helps
Hope this helps
