Homer4beer
Well-Known Member
While late night surfing on auction sites I type in a few turntable make and models (finding a NOS Kenwood KP-1100 in the process that sold for $1800 however I passes on it, too steep for me once duties and shipping accounted for) and stumbled across a Sansui XR-Q7 that said the following;
Having a good XR-Q7 and knowing that unless the tonearm assembly is functioning correctly the motor won't start I took a punt and placed a bid. I ended up winning it for the grand sum of Au $62 plus Au $280 for shipping.
It arrived today packaged quite well except the muppets simply taped the platter down instead of removing it and packing separately.
Sure enough it came off during shipping and damaged the black plastic cover under the platter which protects the motor.
Anyway, I powered it up and the motor for the tonearm works, the belt is good, it returns the arm to the rest if I manually move it away and let go, however it will not lower the tonearm. There is an issue there so I'm hoping that I can take the tonearm apart and have a crack at fixing it. If I don't have any success at least I have some spare parts to keep my other two in operation
Underneath the tonearm in all its glory.
Here goes nothing!
Into the guts of the beast I go!
It does not rotate. There exterior scratches and dirt. junk.
If you're not clear about anything, please ask. Thank you.
Please judge in the image.
Here goes nothing!
So now I just to find a replacement LED.
