Fixing the SME 3009/3012 arm rest
samid
Hi guys,
The arm rest on my SME 3009 is loose, in fact I can pull it out completely. If I push it back in it stays in place and "works" (i.e. supports the arm fine) but is still too loose and can be rotated around:
What is the proper way to fix it in place?
Thanks!
Look on the side there is a set screw that needs tightening. Left side facing the arm. you will see the hole. I believe it to be a 1.5mm set screw.
This is the most documented tonearm on the web. Time to grab a number of the documents from the web and maybe even walk through the set up one more time to get the most out of the arm.
