Flying C vs GE 6550
RobertVL
I picked up 2 pairs of Svetlana Flying C 6550 for my Luxman , I have GE 6550 in now
Usually when I audition speakers or wires , I put ony left and then listen to both and decide which one I like
How about tubes?
Can I do the same for tubes?
Or must I change all tubes at the same time to maintain bias?
You can do the same thing with the tubes. Check and adjust the bias for each tube or pair depending on how your amp is set up.
Within the American production 6550 tubes, the original Tung Sol, as well as the GE, MPD, and Sylvania versions all produce about the same amount of power output, but the GE and MPD versions of the tube were the most consistent in approaching the lowest levels of distortion achieved by the original Tung Sol product. These tubes still remain the benchmark of performance and durability within this family of tubes.
Within the import tubes, the 6550C from Svetlana was the best of the imports, even employing gold plated control grids for enhanced stability, which was a marked improvement over their previous "B" version of this tube.
All of the imports struggle to produce the power capability of the classic American pieces, with the best ones producing about 90% of their capability. Still, the import versions of this tube have improved significantly over the years, with their distortion performance reaching very acceptable levels with regards to the American pieces.
From a durability standpoint, it is rare to find an import that can go the distance that the classic American pieces can, but within this framework, the import tubes do offer a workable replacement for this wonderful tube.
I hope this helps!
Dave
I believe you will notice right away the difference in bass response. Thats just my (2 cents) experience using newer tubes vs NOS Tung Sol or GE 6550's, in McIntosh and ARC gear.
