Paul C
Then do yourself a favor and run coax up to the attic. If you later put up an outside antenna, you can couple to the end of the coax you have going to your indoor antenna. If the run is short, directly to a room below, twinlead will do OK. You can get some specialized wall plates with F connectors (for coax), and blank ones. You could put a couple of binding posts for attaching twinlead.
