OscarEmmy
VHFSE Originator/Blogger
I have a problem with an LXI (Sanyo) 562 receiver (75w per channel) that only affects FM.
1) It works flawlessly on AM, Phono, AUX at any listening level up to full volume.
2) On FM and FM MPX it only works well up to about a 1/4 turn of the control. Beyond this level, loud distortion occurs. The distortion stops when I reduce volume again.
3) If I press the Loudness button the distortion tends to occur sooner (as sound levels increase).
4) The point at which distortion occurs depends on input level - for example, quiet music or voice during an FM transmission remains distortion free at higher gain levels compared with, say loud rock music.
5) I also note that when distortion kicks in, the FM signal strength indicator falls to a lower level.
6) The problem does NOT occur when listening through headphones, only when playing through speakers. I have tried different speakers, all with the same result.
I have never come across anything like this before. Can anyone suggest a cause and/or remedy?
